LET OP: SRAM FORCE VOORREM TERUGROEPACTIE
oyah
oyah 13 feb 2007 09:41
Nou begrijp ik pas die eerdere marketing slogan : "Will you make the leap?"
Fiets... ook eens 11 speed!
lancev7
Gebruikersavatar lancev7 13 feb 2007 21:32
nu wordt ook de achterrem terug geroepen
http://www.velonews.com/tech/report/art ... 645.0.html
SRAM expands brake recall
By Matt PacochaVelonews technial writer
This report filed February 13, 2007
Less than a week after SRAM announced a voluntary recall of a limited number of Force front brake caliper, the company has expanded the recall to include rear calipers. The expansion is due to incorrect grain structure in the titanium used to manufacturer the caliper mounting bolts of both front and rear brakes.
SRAM urges consumers not to ride a bicycle equipped with the affected brakes. The mounting bolt can fail causing the brake caliper to detach from the frame of fork.
SRAM assures its partners that the issue has been corrected and that it has ended its relationship with the suspect supplier. The problem affects roughly 10,000 Force brake calipers and does not affect the Rival group. The recall expansion does not include any brake calipers manufactured outside of the date range previously reported.
Date Codes/Range Affected • No date code • Original date code range: 01JUNE06 to 15SEPT06 (date code indicated production day, month and year) • Current date code range: 35T6XXXXXXX to 39T6XXXXXXX (first two digits indicate week of production, 2006)
"The expanded recall is motivated by additional metallurgical analysis coupled with one failed rear mounting bolt," said Michael Zellmann SRAM's media and PR manager. "It's essentially a bad batch of titanium."
SRAM will replace any Force caliper that was produced during the affected manufacturing period. Consumers are instructed to contact their dealer or place of purchase for replacement.
ilfalco2004
ilfalco2004 13 feb 2007 23:32
Mijn FM wist van NIKS.  En nog steeds geen website vermelding.....vreemde zaak.
Fly like an Eagle!
Old Warriors Never Die
arnoud
arnoud 14 feb 2007 11:19
Misschien hebben die produktie weken Nederland niet bereikt?
http://www.cyclemania-c.com" onclick="window.open(this.href);return false;
ilfalco2004
ilfalco2004 14 feb 2007 12:57
wel in nederland hier de nederlandse versie.
SRAM heeft ontdekt dat sommige SRAM Force voorremmen van defecte titanium bevestigingsbouten voorzien zijn. Dit probleem werd sindsdien verholpen en betreft niet ALLE scharnierbouten van Force voorremmen. SRAM zal alle Force voorremmen vervangen die binnen de hieronder gespecifi ceerde tijdruimte werden geproduceerd.Gebruik de fiets niet totdat de voorste Force remklauw is vervangen.
BETREFFENDE PRODUCTSRAM Force race-remklauw - alleen vooraanSRAM Force, achterrem, Rival, voor- en achterrem - geen probleemDEFECTBreuk van bevestigingsbout wanneer bevestigd aan vork.De bevestigingsbout kan breken waardoor de voorste remklauw van devork loskomt.Tijdens het rijden kan de fi etser dan de controle over de fi ets verliezen.OORZAAK• Verkeerde korrelstructuur van de titanium grondstof.DATUMCODES/REEKS MET PROBLEEM(de datumcode op de achterkant van de remklauw zal een van de volgende zijn)• Geen datumcode (eerste productie had geen datumcode)• Originele formule datumcode: ≤ 15SEP06 (tot en met 15SEP06)• Huidige formule datumcode: 35T6XXXXXXX - 39T6XXXXXXX (eerste twee cijfers geven productieweek aan, 2006)
CORRIGERENDE ACTIE:Vervangen van de volledige Force voorrem (de bevestigingsbout kan niet worden vervangen).Part Number: 00.5112.318.050 07 BR, Force, vooraan, lengte moer: 30 mm.
Dat wordt in mijn geval beide remmen omruilen, de sram groep schakelt overigens goed (niet slechter dan DA of Record).
Fly like an Eagle!
nemo
nemo 22 feb 2007 19:51
Kan iemand mij het antwoord geven. Mijn FM zegt dat het alleen om de voorrem gaat en wil ook alleen deze vervangen. Hier lees ik dat intussen ook de achterrem wordt teruggeroepen en kom ik op internet ook beide berichten tegen.
Hoe zit het nu echt?
