Klachten, vragen, suggesties...doe 't hier.
Storing?
JM_H
Gebruikersavatar JM_H 29 jun 2015 11:26
+1 (of eigenlijk heel veel ;) )
JPAR
Gebruikersavatar JPAR 29 jun 2015 11:37
Idem
Basso Astra - Wilier Gran Turismo - http://www.dvn.nl/
Zorro
Gebruikersavatar Zorro 29 jun 2015 12:29
Maar als de pagina nogmaals probeert te laden dan gaat het vaak wel goed. Ik heb de precieze melding niet meer voor houden maar lijkt een communicatie probleem van Web Server met de SQL server.
U2-11 O'Clock Tick Tock
Soap
Gebruikersavatar Soap 29 jun 2015 13:43
+ 1
Canyon Ultimate CF SL team (2015)
Pinnacle Arkose 2 (2015)
monsieurpinot
Gebruikersavatar monsieurpinot 24 jul 2015 15:31
heb sinds gisteravond ook weer veelvuldig last van deze foutmelding:
JPAR
Gebruikersavatar JPAR 24 jul 2015 15:33
Ik ook. En ook heel vaak dit keer :?
Spaceship
Gebruikersavatar Spaceship 24 jul 2015 18:12
Het betreft een: Too many connections problem.
B.5.2.7 Too many connections
If you get a Too many connections error when you try to connect to the mysqld server, this means that all available connections are in use by other clients.
The number of connections permitted is controlled by the max_connections system variable. The default value is 151 to improve performance when MySQL is used with the Apache Web server. (Previously, the default was 100.) If you need to support more connections, you should set a larger value for this variable.
mysqld actually permits max_connections+1 clients to connect. The extra connection is reserved for use by accounts that have the SUPER privilege. By granting the SUPER privilege to administrators and not to normal users (who should not need it), an administrator can connect to the server and use SHOW PROCESSLIST to diagnose problems even if the maximum number of unprivileged clients are connected. See Section 13.7.5.30, “SHOW PROCESSLIST Syntax”.
The maximum number of connections MySQL can support depends on the quality of the thread library on a given platform, the amount of RAM available, how much RAM is used for each connection, the workload from each connection, and the desired response time. Linux or Solaris should be able to support at 500 to 1000 simultaneous connections routinely and as many as 10,000 connections if you have many gigabytes of RAM available and the workload from each is low or the response time target undemanding. Windows is limited to (open tables × 2 + open connections) < 2048 due to the Posix compatibility layer used on that platform.
Increasing open-files-limit may be necessary. Also see Section 2.5, “Installing MySQL on Linux”, for how to raise the operating system limit on how many handles can be used by MySQL.
Gebruikersavatar Orlok 24 jul 2015 18:42
Ik heb deze melding ook weer veelvuldig vanavond. Maar op de hoofdpagina van dit forum staat:
Er zijn in totaal 66 gebruikers online :: 24 geregistreerde, 1 verborgen en 41 gasten (gebaseerd op de gebruikers die de laatste 5 minuten actief waren)
Het grootst aantal gebruikers online was 453 op 08 apr 2015 22:24
Met andere woorden er is ook iets anders aan de hand want het maximum aantal gebruikers online wordt vandaag bij lange na (nog) niet gehaald.! ;)
monsieurpinot
Gebruikersavatar monsieurpinot 24 jul 2015 18:47
Orlok schreef:Ik heb deze melding ook weer veelvuldig vanavond. Maar op de hoofdpagina van dit forum staat:
aantal gebruikers zegt waarschijnlijk niets over de aanvragen die er op de MySQL database worden gedaan. Daar gaat er waarschijnlijk iets mis (kunnen wellicht ook scriptfouten, spambots, DDOS aanvallen etc etc zijn, werkelijke reden laat ik graag aan een expert over ;) )
NicoNB
Gebruikersavatar NicoNB 31 okt 2016 08:04
Het forum is vanochtend behoorlijk traag.
Misschien een idee om de server even een schop te geven. :roll:
LoneWolf
Gebruikersavatar LoneWolf 31 okt 2016 09:29
NicoNB schreef:Het forum is vanochtend behoorlijk traag.
Is mijn devies: "Ein reboot macht alles wieder gut". :like:
Heb trouwens zelf nog niets gemerkt van traagheid e.d.
Keep On Harking !
NicoNB
Gebruikersavatar NicoNB 31 okt 2016 09:31
Het forum werkt bij mij inmiddels weer zoals ik gewend ben, snel.
