01 okt 2015 07:19
Dat lijkt dezelfde als die van Trek in april.
monsieurpinot
monsieurpinot
01 okt 2015 08:04
ja, las jouw post ook al, en bedacht me dat ook, alleen hier gaat het ook over andere merken (misschien was trek er al vroeg bij
Soap
Soap
08 dec 2015 22:33
Pinnacle and Hoy Hanger Safety Recall impacting 2015/16 Disc Brake models of:
Arkose, Pyrolite, Dolomite, Cobalt, Lithium and Shizuoka
Dear Evans Cycles Customer,
Our records indicate that you have purchased one of the above listed bikes from us and unfortunately we are contacting you as your bike is subject to a recall.
We have received reports of rear wheel slip issues on some Pinnacle/Hoy bikes sold since late 2014. We have identified an issue with a small number of rear mech hangers that can result in the rear wheel slipping. The rear mech hanger is a separate replaceable part that is attached to the frame and the rear gear mechanism attaches to it. It is designed to protect the frame from potential damage.
To ensure the continued safety of our customers, we are conducting a recall on models using this hanger and replacing those for all customers, along with the associated nut and bolt. As a precaution, please discontinue use of your bike until the new hangar has been fitted.
We are in the process of placing orders for the hanger and would appreciate if you could confirm the delivery address at your earliest convenience, otherwise, this will be sent to the address we have on file for your account.
Please do not hesitate contacting us if you have any questions or concerns.
We apologise again for any inconvenience and look forward to getting you back on your bike as quickly as possible.
Kind regards
The Product Recall Team
Evans Cycles
Canyon Ultimate CF SL team (2015)
Pinnacle Arkose 2 (2015)
tieky
tieky
09 dec 2015 09:28
Nog meer schoonheidsfoutjes bij de schijfremmen
MELDING VAN TERUGROEPACTIE
7 december 2015
Beste,
Sommige Cannondale modellen zijn uitgeleverd met disc brakes en een QR die, als niet juist gesloten of open gelaten tijdens het rijden, in de remschijf kunnen komen. Een voorbeeld van een QR met een hendel die zover kan openen dat het een potentieel gevaar oplevert wordt getoond in voorbeeld 1 hieronder. Een voorbeeld van een correcte QR is te zien in voorbeeld 2 hieronder. Mocht de fiets zijn uitgerust met een incorrecte QR en met schijfremmen kan het gebeuren dat de hendel bij loskomenof niet goed sluiten in de remschijf komt. Als dit gebeurt kan het voorwiel loskomen of de fiets abrupt tot stilstand waardoor de rijder de controle verliest en mogelijk serieus gewond raakt.
Betrokken modellen: Elke Cannondale fiets uitgerust met schijfremmen en een QR waarbij de hendel in volledig geopende stand de schijf kan raken is onderdeel van deze terugroep actie. Modellen met een minimale afstand van 6mm tussen de remschijf en hendel van de volledig geopende QR vallen buiten deze terugroep actie. U kunt een video demonstratie van de QR controle vinden door te klikken op de volgende link:
http://www.quickreleaserecall.com .
WAT DOET CANNONDALE VOOR BEZITTERS VAN EEN BETROKKEN FIETS: Als u een fiets heeft die onderdeel is van de terugroep actie zal Cannondale u via uw Cannondale dealer voorzien van een gratis QR, incl. instalatie.
Met vriendelijke groet,
Cannondale Europe
NoChain
NoChain
28 dec 2015 12:26
Dat lijkt me nu typisch zo'n voorbeeld waarbij een Europees merk nooit een terugroepactie zou doen. Als wij onze snelsluiting tot in onze schijf duwen dan weten we dat we lomp zijn geweest, in Amerika gaan ze dan in proces.
17 mar 2016 08:41
epotheker
epotheker
29 mar 2016 17:48
Hoe kan het dat mijn fietsenmaker de racall betreffende de Zipp-naaf niet in behandeling wil nemen.
Doet de Zipp importeur in Nederland moeilijk? Krijgt mijn FM de ksoten niet vergoed?
Andere gebruikers soortgelijke ervaringen?
Bredalp
Bredalp
21 apr 2016 20:57
Zag er weer 1 van Cannondale. Als je een Slate hebt. En je wilt tubes doen ipv binnenband, dan kan de band uit de velg floepen.
Kan gratis nieuwe wielen krijgen. Bij normaal gebruik geen gevaar, dus alleen als je tubes wilt gebruiken.
Stond op facebook.
marcels
marcels
25 apr 2016 17:00
NicoNB
NicoNB
21 jul 2016 21:59
Cannondale 2010 - 2012 Bad Boy- en Bad Girl- fietsen
Deze terugroepactie is het gevolg van meldingen over fietsen die scheurtjes krijgen door metaalmoeheid op de plek waar de as bij de vorkarm komt. Scheurtjes door metaalmoeheid breiden zich uit tijdens het gebruik en kunnen resulteren in een gebroken as. Er bestaat kans dat de as loskomt van de vorkarm, met risico op ongevallen of letsel tot gevolg.
Gebruik de fiets niet totdat de vork is gecontroleerd of vervangen. Fietsen die zijn teruggeroepen kunnen worden geïdentificeerd aan de hand van de datumcode op de onderkant van de vorkarm.
