True Temper Sports Wolf SL Fork Voluntary Recall
Cervélo has identified a potential safety issue involving the Wolf SL fork. This fork is designed and manufactured by True Temper Sports of Memphis, Tennessee, using a blade shape supplied by Cervélo. All other aspects of the structural design, development and manufacture were done by True Temper Sports.
Under certain conditions, the fork steerer can crack and eventually break during normal use, which may cause the rider to lose control, fall and suffer potentially serious injuries. To date, there have been reports of injuries in the field resulting in minor abrasions and one broken wrist.
Though the fork passes US and international standards, this particular problem was not uncovered during those standard tests and the fork only showed this weakness in the field, typically after being damaged. After much work, we did develop a new test protocol that was able to replicate the same failure mode as seen in the field. If the fork steerer is damaged by impact (eg. by a crash, a fall from a roof rack, or another impact) then the damage may progress very quickly during use to complete separation.
We have seen that incidence of failure on this fork is higher than on other forks, and there is a potential for injury upon failure. True Temper Sports feels that the fork meets the industry standards and that the fork is therefore acceptable and no further action is required. Cervélo does not share this opinion and therefore, is proceeding with a recall of the True Temper designed and manufactured Wolf SL forks ourselves. True Temper Sports has declined to participate.
In order to conduct a recall one must be able to demonstrate that any replacement product does not display the same failure mode. We have demonstrated to the authorities that the forks we will use as a replacement - the 3T Funda Pro and the Easton EC90 SLX - pass all standard industry tests as well as the new Cervélo test that the True Temper Wolf SL fork fails.
We have obviously discontinued all use of the True Temper Wolf SL carbon bicycle fork. However, please note that this does not affect the Wolf CL and Wolf TT in any way, as both have a completely different structural design (and have passed the new Cervélo test protocol).
Although it is not usual for a third party to recall a product manufactured by another company, we feel it is a necessary step to take care of our customer, and we will proceed with the full recall at no cost to the dealer or consumer.
© photo - Tim De Waele / Cervélo
If you do not wish to receive Cervélo éNews, please click here
www.cervelo.com
éNews text contents may be used free of charge provided Cervélo is credited as follows: “courtesy
www.cervelo.com/enews". Photos may only be used if listed at
www.cervelo.com/media. All other photos are © Tim DeWaele and may not be reproduced.
