litespeed schreef:C a s r a n schreef:Hij zegt dat het probleem heel beperkt zou zijn.
Op de Cervelo-site staat een aantal wielen genoemd waar mogelijk problemen mee zijn; waaronder de Bora's en Fulcrum Zero's.
Zo wordt je wel erg beperkt in je wielkeuze toch??
These mentioned wheel sets are recommended in combination with the S3.
The S3 is the most aerodynamic road bike, Cervélo ever produced. Therefore we recommend using Aero wheel sets.
As the tolerances are very tight, not every wheel will fit the S3 Frame. Especially wide spoked wheels can interfere with the chain stay.
Manufactuer Model
Blackwell Disc
Bontrager Aeolus
HED 2008 Jet (all)
H3, all
2008 Stinger 50
2008 Stinger 60
2008 Stinger 90
Mavic Cosmic Carbone Ultimate
Cosmic Carbone SL
Reynolds DV66 2008/09
DV46 2008/09
Disc TT
Topolino
C19
Zipp
900 disc
The below mentioned wheels are very tight fit. It depends on the use and on the weight of the rider whether these wheels will interfere with the chain stays.
Manufactuer Model Notes
Campagnolo Bora Ultra Two <2mm spoke/chain stay clearance
Fulcrum Speed XLR <2mm spoke/chain stay clearance
Speed XLR (new hub) <2mm spoke/chain stay clearance
Zero <2mm spoke/chain stay clearance
HED 2009 Jet (all) <2mm spoke/chain stay clearance
2009 Stinger 50 <2mm spoke/chain stay clearance
2009 Stinger 60 <2mm spoke/chain stay clearance
2009 Stinger 90 <2mm spoke/chain stay clearance
Zipp Sub 9 disc, '09 model rider weight/riding style dependant
The below mentioned wheels do not fit the S3.
Manufactuer Model
Campagnolo Hyperon
Mavic R-Sys
Wheels which are not added to the list should be checked with your dealer.
We will update the list whenever we can.
