Schone dames!
mimarron
mimarron 24 jan 2016 16:38
wel een mooie fiets , welk merk kan ik niet niet kezen ....
Sensa GF 2022
Eddy Merckx EMX525 Ultegra...2016 ( verkocht )
Koga BeachRacer 2016 ( verkocht )
Deleted_User
Deleted_User 24 jan 2016 17:37
Avenue
Nee_Nee
Nee_Nee 24 jan 2016 18:20
ik zou zeggen: handen aan het stuur en je zadel wat omhoog.
mimarron
mimarron 24 jan 2016 20:17
afrit13 schreef:Avenue
dank je ,en gevonden
Sensa GF 2022
Nee_Nee
Nee_Nee 25 jan 2016 21:41
Even een kort stukje tekst over vangrails. Heel belangrijke stukken straatmeubilair waar je nauwelijks bij stilstaat.
A guardrail is a system designed to keep people or vehicles from (in most cases unintentionally) straying into dangerous or off-limits areas.
In traffic engineering, highway guardrail may prevent an errant vehicle from impacting roadside obstacles which may be either man-made (sign structures, culvert inlets, utility poles) or natural (trees, rock croppings), running off the road and going down a steep embankment.
A secondary objective is keeping the vehicle upright while deflected along the guardrail. The most common type of guardrail in use today is the Blocked-Out W-beam (Strong Post), as seen here.
Strong-post W-beam guardrail consists of wood posts and wood blockouts or steel posts with wood or plastic blockouts. The blockouts reduce or minimize a vehicle snagging on the posts upon impact. In addition, a blockout may be used to increase the offset of guardrail with an obstacle such as a curb.The posts' primary purpose is to maintain the height of the guardrail during the initial stages of post deflection.
Maintaining guardrail height also reduces the potential for a vehicle to vault over the guardrail upon initial impact. The posts also play a role in the amount of resistance and deflection a guardrail may experience during impact. Resistance in a strong post system results from a combination of tensile and flexural stiffness of the rail and the bending and shearing resistance of the posts. #thankyouguardrails
Puffdaddy
Gebruikersavatar Puffdaddy 25 jan 2016 22:44
Ik zie 2 bergen (op de mouw).
Bikers are not alone
senior
senior 25 jan 2016 23:03
puffdaddy schreef:Ik zie 2 bergen (op de mouw).
Vanzelfsprekend. Bij die bergen op de mouw valt de rest niet meer op (ik laat me niets op mijn mouw spelden, ik heb jou in de gaten) :lol:
Puffdaddy
Gebruikersavatar Puffdaddy 25 jan 2016 23:34
Daar heb je 2 punten :D
Gebruikersavatar Ernie C. 25 jan 2016 23:46
Dat zijn geen punten, dat is de visuele ondersteuning om ons en duidelijk beeld te geven van het profiel van die w-beam vangrails.
patmaessen
patmaessen 26 jan 2016 08:15
Nieuwe 'canyon' team. :lol:
Supergrover
Gebruikersavatar Supergrover 26 jan 2016 09:16
Heb nu 3 keer gekeken, ik zie geen vangrail in het plaatje...
"nat hout brandt niet!! "
Bianchi via Nirone 7
Nee_Nee
Nee_Nee 26 jan 2016 10:07
Supergrover schreef:Heb nu 3 keer gekeken, ik zie geen vangrail in het plaatje...
Zo wel, Grover?
