Cube Acid, attention, ltd pro of ltd team. graag advies
intertedzo
intertedzo 02 nov 2008 16:39
Ik ben op zoek naar een mountainbike, budget ongeveer 1000 euro. Ik ben een beginner. Ik ben erg gecharmeerd van Cube, alleen weet ik niet wat de beste keus is. De keuze is tussen de Acid, Attention, LTD pro en LTD team. Graag jullie advies, tips etc.
Alvast bedankt.
Ted
ps. hieronder de specificaties (bron. Cube.Bike-zone.nl)
Acid: (749 euro)
• Frame - Alu Lite 7005 RFR-Geometry
• Size - 14", 16", 18", 20", 22"
• Colour - Black/Grey or White Candy Blue
• Forks - Rock Shox Dart 3 80mm, PopLoc
• Headset - FSA No.10 semi-integriert
• Stem - FSA OS190
• Handlebars - FSA XC300 Lowriser
• Rear Derailleur - Shimano Deore XT Shadow
• Front Derailleur - Shimano Deore
• Gear shifter - Shimano Deore Rapidfire-Plus 9-speed
• Brakes - Stroker Ryde hydr. (180/160mm)
• Crank set - Shimano M442 Octalink 44x32x22Z., 175mm, Shimano BB-ES25
• Cassette - Shimano HG50 11-32T, 9-speed
• Chain - Shimano HG53
• Rims - RFR ZX24
• Shimano Disc M525
• Tyre - Schwalbe Smart Sam 2.1
• Pedal - Fasten Alu
• Seat - Scape Active 5
• Seat post - Scape Light 31.6mm
• Weight - 1950 g
Attention: (649 euro)
• Colour - Black/Grey or White/Black
• Forks - Suntour XCM Lockout 80mm
• Stem - FSA OS190
• Brakes - Shimano M485 hydr. Scheibenbremse (180/160mm)
• Crank set - Shimano M442 44x32x22Z., 175mm, Shimano BB-UN26
• Rims - RFR ZX24
• Shimano Disc RM65
• Weight - 1950g
LTD pro: 949 euro
• Frame - Alu Superlite 7005 Double Butted, RFR-Geometry
• Size - 16", 18", 20", 22"
• Colour - Black Anodized or White Candy Black
• Forks - Rock Shox Tora SL Solo Air 100mm, PopLoc
• Stem - Easton EA30
• Handlebars - Easton EA30 Lowriser
• Front Derailleur - Shimano SLX
• Brakes - Stroker Trail hydr. Scheibenbremse (180/160mm)
• Crank set - Shimano Deore 2-Piece 44x32x22Z., 175mm, integr. Innenlager
• Rims - RFR ZX24
• Shimano Disc M525
• Tyre - Schwalbe VR: Nobby Nic Triple Compound 2.25/HR: Racing Ralph TC 2.25
• Seat - RFR Natural Shape 0.1 M
• Seat post - Easton EA30 31.6mm
• Weight - 1850g
LTD team: (1049 euro)
• Colour - Black Anodized or Black Candy Green
• Forks - Rock Shox Reba SL 100mm, Motion Control, PopLoc
• Brakes - Formula Oro K18 hydr. (180/160mm
• Rims - RFR ZX24
• Weight - 1850g
kaj1500
kaj1500 02 nov 2008 17:22
Tsja...
Is je budget alleen voor de bike? Of moet je daar nog kleding, schoenen, helm, spul voor onderhoud etc. van kopen?
brummi
brummi 02 nov 2008 17:55
als het budget het toelaat dan de LTD team, ik ben er zelf zeer tevreden over en op termijn zal de investering zeker lonen tegenover de andere modellen
intertedzo
intertedzo 02 nov 2008 21:56
Het budget is alleen voor de bike.
bigm
bigm 02 nov 2008 23:09
Qua onderdelen de ltd team ,maar omdat je een beginner bent zal je het verschil tussen de verschillende onderdelen niet echt merken,omdat je geen vergelijking kan maken
als ik zou moeten kiezen tussen een frame wat ik mooi zou vinden en mindere onderdelen of een frame wat ik minder mooi zou vinden met betere onderdelen zou ik het wel weten
upgraden kan altijd later nog maar dan heb je wel het frame wat je mooi vind geometrie moet wel passen natuurlijk want die is anders volgens mij bij de genoemde modellen
GEOMETRIE
>De LIMITED modellen hebben een langere bovenbuis dan bijvoorbeeld de ACID modellen
>De LIMITED modellen hebben een kortere bovenbuis dan de REACTION en ELITE modellen
deze info komt van bike2build.nl
ts-biker
Gebruikersavatar ts-biker 02 nov 2008 23:22
de Team komt met een Reba en da's toch wel een groot pluspunt !
bigm
bigm 03 nov 2008 00:00
TS-Biker schreef:de Team komt met een Reba en da's toch wel een groot pluspunt !
idd
intertedzo
intertedzo 03 nov 2008 10:54
wat is een Reba?
mcf1
mcf1 03 nov 2008 11:01
een hele goeie voorvork...
kaj1500
kaj1500 03 nov 2008 14:33
De Rockshox Reba maakt het verschil tussen de twee LTD's. Een Reba staat duidelijk hoger dan een Tora(air), waar ook prima mee te rijden is. Ga eens een stukje rijden, dan weet je of zo'n LTD wel goed zit voor jou. Misschien is het verstandig om tzt toch ook eens naar een ander merk te kijken, qua geometrie? Bijv. Focus, Stevens, Bulls, merken die zo'n beetje hetzelfde doen op de fietsmarkt.
cubemeister
cubemeister 03 nov 2008 21:09
let op dat de ltd modellen en de acid's een andere geometrie hebben. de ltd's hebben een wat langere bovenbuis de acid is geloof ik vrij kort --> zie www.bike2build.nl
de ltd wordt over het algemeen als zeer goed beoordeeld
tarmac expert sram force
venge pro race sram force 22
BMC TE02 xt/xtr
laulau
laulau 04 nov 2008 22:08
Recentelijk heb ik voor dezelfde keuze gestaan. Het is uiteindelijk de LTD Team geworden en wel vanwege de prima vork (Rockshox Recon) en de K18 schijfremmen. Off-topic wellicht, maar deze componenten lopen behoorlijk in de papieren om te upgraden en kun je dus naar mijn mening beter maar gelijk goed kopen. Met de zitpositie van de LTD zat het voor mij snel goed :-)
Misschien de moeite van overwegen waard, maar wil je nu een fiets kopen, daar wat ervaring mee opdoen en vervolgens een duurdere/betere fiets kopen of denk je deze te willen upgraden naar behoefte? Daarmee kun je ook al aardig inschatten welke de juiste voor jou is, met het maken van de proefrit natuurlijk!
Succes met de keuze!
Cube AMS Comp 2010
Next: Specialized Roubaix òf Bianchi Via Nirone C2C ??
