Ritchey WCS Protocol?
lars1976
lars1976 22 mar 2006 14:02
Heeft iemand ervaring met Ritchey WCS Protocol wielen? Zo ja, zijn er dan voor- of nadelen?
Ik twijfel namelijk nogal of ik ze wel aan moet schaffen.
Geld=wielrennen, wielrennen=geld, dus duur.
zorankalaba
zorankalaba 24 mar 2006 12:34
WCS protocol wielen; I have a very close contact with these wheels every day.Some of those sets where been used by one of the continental teams in 2004.
The wheels itself suprised me with keeping a straight line and not giving problems regarding
spoke breakage.Altough they have only 24 spokes in the rear wheel and 20 in the front,if my memory
is giving me the right data...
But; the bearings are the problem.WCS and American Classic use 15x26x7 bearings.The numbers are the size of the bearing in mm. MR 1526 2 RS is the code of the bearing.
These bearings are very difficult to find.
Both hubs come out of the production with some bearings made in China. They worn out quickly, unfortunately.
But WCS and American Classic hubs are equiped with Enduro ,or Enduro max, those bearings will give you thousands of KMrs without problems.
Enduro and Enduro Max bearings are available in the exclusive 15 x 26 x 7 mm size. Both are high quality, using grade 25 bearings (Dura Ace, XTR, Campy grade), while the Enduro Max is of the full-compliment type.
If you want to replace them by yourself, be careful with the cassette body. Don't put too much grease in the housing of the body.
Too much grease can jam the spring which realeases the drive mechanism from catching.
http://www.bikexperto.com" onclick="window.open(this.href);return false;
guser
guser 25 sep 2006 18:25
Hi,
Is het bearing issue with Ritchey Protocol wheels still actual? Via bikestudio.nl there is an interesting offer for this wheel. I wonder if they still sell it with the faulty bearing, or with a new type.
Guser
spietpiet
spietpiet 26 sep 2006 00:47
Quote: Origineel geplaatst door Guser op 25 September 2006
Hi,
Guser
Contact bikestudio and ask it, I bought a set in Dalen and the body was modified, there is no problem with the bearing.
I'm very happy with this wheelset.
wezep
Gebruikersavatar wezep 26 sep 2006 10:41
Is dit opeens een Engels forum of zo?Heb begrepen dat deze wielen bij Bikestudio te koop zijn voor 315 euro.Lijkt me niet veel geld voor een setje wielen van goed 1500 gram.
Gravel: Giant Revolt
ATB: Giant XTC
TT: Giant Trinity
guser
guser 27 sep 2006 16:41
Inmiddels van Bikestudio begrepen dat de aanbieding modeljaar 2007 wielen betreft, met een andere body en 2jr garantie. Qua specs klinkt het dus wel goed (1500g, aero spaken etc.)
Maar rijdt het ook een beetje, iemand een idee?
spietpiet
spietpiet 27 sep 2006 21:55
Ben in bezit van een wielset WCS Protocol.
Voor mij voldoen deze wielen prima, bijna 3000 km mee gereden tot nu toe zonder problemen.
Zijn voor mij ook voldoende stijf met mijn gewicht van 67 kg.
Mijn setje komt onder de 1500 gr, heb het idee dat ze sneller zijn dan m'n Open Pro's met Dura Ace naven.
