Hallo,
Omdat ik een nieuwe fiets van de sponsor heb gekregen, bied ik (met pijn in mijn hart) mijn Specialized Stumpjumper Comp Carbon aan. Ik vind het zonde om deze fiets in de schuur te laten staan en er nooit op te fietsen...
De fiets is in juli 2010 aangeschaft en is altijd zeer goed onderhouden. Alle onderdelen nog als nieuw!
Merk: Specialized
Model: Stumpjumper Comp Carbon
Maat: 19 inch
Wielmaat: 26 inch
Prijs: 1750 euro
Staat: 9/10
[FRAME]: FACT 8M carbon, 1.5 - 1-1/8" tapered HT, replaceable alloy derailleur hanger, alloy dropouts
[VORK]: Fox Float F90 RL, 90mm travel, air spring, compression and rebound adj. w/ LO, alloy steerer
[BALHOOFDSTEL]: 1-1/8" Threadless, Campy style upper and lower cartridge bearing
[STUURNOK]: 3D forged alloy, adjustable rise, 31.8mm clamp
[STUUR]: Specialized XC low rise bar, 7050 butted alloy, 31.8mm, 660mm wide, 8 degree back sweep, 6 degree up
[HANDVATTEN]: Specialized Thick lock on grip
[BAR-ENDS]: Ritchey WCS White
[VOORREM]: Custom Avid Elixir R SL, alloy backed organic pads, 160mm rotor
[ACHTERREM]: Custom Avid Elixir R SL, alloy backed organic pads, 160mm rotor
[REMHENDELS]: Custom Avid Elixir R SL Hydraulic, tool-less adj. reach
[VOORDERAILLEUR]: Shimano M660 SLX, DMD, top swing, dual pull
[ACHTERDERAILLEUR]: SRAM X-9, 9-speed, mid cage
[SCHAKELHENDELS]: SRAM XO Gripshift 3x9 speed
[CASSETTE]: Shimano XT, 9-speed, 12-27t
[KETTING]: Shimano Dura-ace, 9-speed w/Power Link
[CRANKSTEL]: Shimano XT, 175mm
[TANDWIELEN]: 44A x 32A x 22S, 4-bolt, 104/64mm
[TRAP-AS]: Custom Shimano BB-91, OS, press-in bearing
[PEDALEN]: Shimano Deore XT SPD Pedal PD-M770
[WIELEN]: Roval Control AL
FEATURES:
Wheelset: 1615g
Rear hub: CNC-machined alloy body, high-quality DT Swiss internals and cassette body, and sealed cartridge bearings
Welded E5 alloy, lightweight disc rim with eyelets; tubeless compatible (24mm W x 16mm H)
Roval quick releases
Oversized 24mm and 28mm end caps included
OS28-compatible for Specialized forks
DT pro lock alloy nipples
24-spoke DoubleDrive front pattern; 28-spoke 3x rear pattern provides added support for drive/disc brake loads on the rear wheel
Hand-built with DT Competition 1.8/1.6/1.8 butted spokes
Q/R: 125g/set
[VOORBAND]: Vredestein Black Panther, 26x2.1", Tubeless
[ACHTERBAND]: Vredestein Black Panther, 26x2.1"
[INNER TUBES]: -
[ZADEL]: Specialized Phenom, hollow Cr-Mo rails, thin foam, 143mm
[ZADELPEN]: 2014 butted alloy, single bolt setback, 30.9mm
[ZADELPENKLEM]: 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
[BIDONHOUDER]: Specialized S-Works Rib Cage
Forumregels
Je hebt er niet veel aan, maar moet wel zeggen dat het een zeer fraaie fiets is. Tis dat ik nog geen andere wil, maar veel succes met de verkoop. Hoop dat ie een goede nieuwe eigenaar zal vinden/treffen.!
It's nice to be important, but it is more important to be nice.
