Trainbaarheid Vo2Max (Meta-analyse)
Comp78
Comp78 23 dec 2013 07:58
Kwam onderstaande studie net tegen in Plos One. Mooie meta-analyse van Vo2Max trainbaarheidsstudies. Kopje "discussion" lezen is vaak genoeg ipv hele studie(opzet) etc.
Copyright: © 2013 Bacon et al. This is an open-access article distributed under the terms of the Creative Commons Attribution License, which permits unrestricted use, distribution, and reproduction in any medium, provided the original author and source are credited.
Bacon AP, Carter RE, Ogle EA, Joyner MJ (2013) VO2max Trainability and High Intensity Interval Training in Humans: A Meta-Analysis. PLoS ONE 8(9): e73182. doi:10.1371/journal.pone.0073182
http://www.plosone.org/article/info%3Ad ... ne.0073182
The benefits of an active lifestyle are well documented [1]–[3]. Many of these benefits are also associated with higher levels of cardiorespiratory fitness (VO2max) which may exert protective effects that are independent of traditional risk factors [3], [4]. Additionally, for individuals with low physical fitness, even modest improvements in fitness can have substantial health benefits. However, some individuals may have a limited ability to increase their cardiorespiratory fitness (trainability) in response to endurance exercise training [5], [6].
A key study advancing the idea that some humans have limited trainability comes from Bouchard et al. studied 483 sedentary white adults from 99 nuclear families who completed a standardized 20-wk endurance training program [5], [6]. The subjects trained three times per week on a treadmill. Initially, they trained at a heart rate that correlated to 55% of their baseline VO2max for 30 minutes per session. Every two weeks the intensity and duration of the exercise was progressively increased until each subject was training for 50 minutes at a heart rate associated with 75% of their baseline VO2max. This level of intensity and duration was reached by the 14th week of training and maintained until the conclusion of the study. Using this approach, they found a mean increase in VO2max of ~0.4 L · min−1 with a SD of >0.2 L/min. Additionally, 7% of subjects showed a gain of 0.1 L · min−1 or less while 8% of subjects improved by 0.7 L · min−1 or more.
Based on this distribution of VO2max responses it appears that the “trainability” of at least some subjects is low or non-existent with little or no improvement in cardiorespiratory fitness in spite of 20 weeks of structured exercise training [5], [6]. These observations are in contrast to reports from smaller studies that have used either interval training (IT), or interval training in combination with continuous training (CT) and shown more robust increases in VO2max with at least some evidence of marked responses in all subjects [7]–[15].
In this context, we sought to explore the hypothesis that all subjects can show marked improvements in VO2max if training programs that include periods of high intensity (~90% of VO2max) exercise are used. A fundamental rationale underpinning our analysis is that the biology of VO2max trainability needs to be evaluated using regimens designed to maximize physiological adaptations. To test this hypothesis, we evaluated the changes in VO2max in response to interval training (IT) or combined IT and continuous training (CT) reported in 37 studies [7]–[43]. We also sought to gain insight into the idea that shorter periods of IT might be either superior or more time efficient at generating increases in VO2max in comparison to traditional continuous training.
Methods
Study Eligibility Criteria and Literature Search
A search of PubMed was developed and conducted by a reference librarian looking for English language studies occurring between the years of 1968–2010 using the following search terms: interval training, VO2max, interval exercise + high/low intensity, maximum O2, maximum/maximal VO2, maximal oxygen consumption, peak oxygen uptake, maximal aerobic capacity, and the following limits: humans, English. The primary author of each eligible study was searched for in PubMed using the authors name and the search term: exercise. Searches were also run on other authors known by the investigators to have published papers that used a combination of interval and continuous training. The references of all eligible studies were also reviewed to identify other potentially eligible studies that might have been missed using the approaches outlined above. Subsequently, these studies were searched for in PubMed using the specific authors and article reference titles. Only published material was used. Figure 1 is a schematic of our search strategy.
thumbnail
Figure 1. Schematic of our study identification and screening approach.
doi:10.1371/journal.pone.0073182.g001
In order to be considered eligible for inclusion, studies had to meet the following criteria:
• Studies had to include a minimum of 3 subjects.
• All subjects were previously healthy and between 18–45 years of age.
• The initial fitness level of the subjects had to fall within the range of untrained/sedentary to recreationally active, defined as 55 ml • kg−1 • min−1 or lower for men and 49.5 ml • kg−1 • min−1 or lower for women. Studies were included with recreationally trained individuals if they were in the minority and if individual data was reported, allowing us to recalculate the pre and post training VO2max values and their associated SDs without the trained individuals. When VO2max was not provided in ml • kg−1 • min−1 a group estimate was calculated using the mean weight and pre VO2max in L min−1.
• Subjects had to train a minimum of 3 days per week for 6–13 weeks. At least two, and preferably three, training sessions had to be interval training.
• Subjects had to be trained on either a cycle ergometer or by running with a minimum work: relief ratio of 1 min on:1 min off.
• During each interval training session subjects had to have a minimum cumulative time of 10 minutes at high intensity. Due to the heterogeneity of training programs in the various studies we felt it was critical for the “work” period of the exercise sessions to be at intensities that were likely at least 80–85% of VO2max or higher. In some studies the desired intensities were set and monitored rigorously via power output or heart rate and in some cases the authors had to make a reasoned estimate. This was especially the case with some of the running training studies that used timed runs (for example reference 23).
• Results had to be reported in pre and post mean VO2max values ± SD or SE, as ranges of change, or individual data.
• Subjects could not be engaged in high intensity training before the start of the study.
Study Selection
Two independent investigators (M.J.J and A.B.) screened the titles and abstracts of all studies identified by the various search methodologies to determine their potential eligibility. Studies that did not have an abstract, along with studies that were deemed potentially eligible, had their full text reviewed in order to determine if they met the criteria for inclusion in the meta-analysis. In order to avoid double counting of studies that reported different aspects of the physiological responses to training, the study design (training methodology, number of subjects, study duration) and subject characteristics (age, pre and post VO2max) of all accepted studies were compared. When studies with common authors, study design, and subject characteristics were found, the study with the larger number of subjects was used. This was done because it appeared that some training studies generated multiple publications with, for example, cardiorespiratory data the focus of one paper, and the metabolic adaptations to training the focus of a second paper.
Data Extraction and Synthesis
Data extraction was performed by one investigator (A.B.) who used a standardized form that allowed for the extraction of study characteristics (author, title, number of subjects, study duration, age range, work: relief ratio, frequency of training, mean pre and post training VO2max values in L · min−1 and in ml · kg−1 · min−1 along with the associated standard errors of the mean (SEM) and standard deviations (SD)).
When needed, pre and post VO2max values, along with pre and post SD values, were converted into L • min−1 to limit the potentially confounding effects of changes in body weight that might have occurred with training. Pre and post SEM values were converted into SD. The calculated values were included in the data extraction sheet. For several studies mean, SD, and pre post correlation were recalculated from individual data. In the majority of studies, only the pre and post measurements were reported (i.e., the standard deviation of the change or the correlation of the pre and post measurements were not reported). Accordingly, the correlation was conservatively set at 0.5 for these cases. When studies reported treadmill and cycle VO2max values, the treadmill values were used.
Summary measures
The principle summary measure utilized was group difference in pre and post training means for VO2max expressed in L • min−1, calculated with a 95% confidence interval using a random effects model [44]. As a sensitivity analysis to the random effects model, a fixed effects model was also fit to the data to estimate the degree of heterogeneity, indicated by I2. We used L • min−1 to avoid the potential confounding effect of significant weight loss and to better compare our analysis with the data from Bouchard et al. [5]. Mean difference was employed as it allowed us to calculate the effect size, which was then compared to the effect size of Bouchard et al. [5]. A standardized change in VO2max (mean change for each study divided by the standard deviation of change) was also analyzed using the same random effects modeling framework.
In order to evaluate the possibility of publication bias, a funnel plot of the mean differences was constructed and assessed. The funnel plot (Figure 2) indicated the potential for publication bias (e.g., smaller studies had larger effect sizes reported), so an imputed model was considered with fictional studies representing the complementary effect sizes to observed studies. A ‘Trim and Fill’ analysis was conducted to further assess for publication bias by providing an estimated pooled effect with the imputed studies while ‘trimming’ (removing) the most extreme small studies [45]. Comprehensive Meta Analysis Software (Biostat) version 2.2.064 was used for all analyses.
Figure 2. Funnel plot of standard errors observed for the reported articles by the reported difference in means.
The open circles are observed studies whereas the solid circles are imputed studies to assess the role of publication on the estimated effect. The two estimates, denoted by the open and filled diamonds for the observed and imputed studies, respectively, agree qualitatively with one another suggesting that the findings may be robust in the presence of publication bias.
doi:10.1371/journal.pone.0073182.g002
Results
Study Characteristics
A total of 211 articles were identified in the initial search. After screening titles and abstracts, 181 articles were discarded as it was apparent that they did not meet the study criteria. Figure 1 is a schematic of our search strategy and displays the criteria for exclusion. The full text of the remaining 30 articles was examined in detail. An additional 70 articles were identified through reference searches. The systematic review resulted in 37 articles for the Meta-analysis. Within these 37 articles were 334 participants (120 women) and 40 unique training groups (i.e., three articles each contained the results of two training programs). In brief, all studies contained between 3 to 19 healthy subjects with an age range of 18 to 42 years and pre training VO2max values ranging from ~26 to 52 ml · kg−1 · min−1.
All subjects trained between 6 and 12 weeks using running, cycling, or a combination of the two modalities with a work relief ratio between 1:1 and 5:2. In all but six studies [10], [14], [15], [17], [32], [38] it was readily apparent that the subjects had trained at high intensity for 10 minutes or more. Knuttgen and Overend reported their work: relief ratios and the duration of their interval training, which allowed us to estimate the number of intervals performed and the time spent performing high intensity exercise which was determined to be greater than 10 minutes [15], [32]. Slordahl reported the duration of their interval training but reported their work: relief ratios as a range [38]. This allowed us to roughly estimate that the subjects performed at least 10 minutes of work at high intensity. Burke reported that their subjects trained to exhaustion; therefore it was assumed that they performed at least 10 minutes of work at high intensity [17. Warburton reported that their subjects performed interval training until the amount of work performed equaled the amount of work that would have been performed by the subject if they had been performing continuous training [14]. Since the subjects in the continuous training group worked for 30–48 min/day at 64.3±3.7% of their VO2max we assumed that the subjects performing interval training worked for at least 10 minutes at high intensity. Finally, Roca reported that their subjects trained less than 10 minutes at high intensity on one day of their high intensity training. Additionally, this was the only study in which interval training did not account for at least half of all training days for the test subjects. However, this exception was justified because the continuous component was judged to be strenuous enough to make up for the diminished interval component [10].
Physiological Responses: Meta-Analysis Results
As a result of the training programs, VO2max increased (p<0.001). The estimated mean change in VO2max over the training programs using the random effects model was 0.51 L · min−1 (95% CI: 0.43 to 0.60 L · min−1) (Figure 2). In terms of standardized effect sizes (estimate divided by standard deviation), the change in VO2max was 0.86 SDs (95% CI: 0.72 to 0.99 SDs).
There was some indication of publication bias in the funnel plot (Figure 2). Specifically, the estimated effect using the ‘Trim and Fill’ approach was 0.37 L · min−1 (95% CI: 0.28 to 0.46 L · min−1), but the number of negative studies required to overturn the observed finding was estimated to be over 4000 (Rosenthal's fail-safe N = 4531) [46]. Thus, while Figure 2 shows a slight attenuation of the result with hypothetical studies imputed to account for potential publication bias, the results are not meaningfully changed. Finally, a sensitivity analysis was also conducted under a fixed effects model. There was significant heterogeneity in the exercise groups (I2 = 70), but the results of this analysis agreed qualitatively with the primary random effects model. Specifically, under the fixed effects model, the estimated change was 0.45 L · min−1 (95% CI: 0.41 to 0.49 L · min−1; p<0.001).
To better illustrate the distribution of effects observed through the systematic review and demonstrated in Figure 3, a weighted histogram and density plot of the observed effects was created (Figure 4). Each of the 40 observations included in the analysis was weighted by the sample size to produce the distribution.
thumbnail
The estimates reported for each study are the means and 95% confidence intervals for the change in VO2max in L · min−1. The summary diamonds at the bottom of the plot represent the summarized effects using fixed and random effects models, where the random effects estimates are considered the primary findings for this study due to heterogeneity (I2 = 70). The estimated increase in VO2max as a result of interval training was 0.51 L · min−1 (95% CI: 0.43 to 0.60 L · min−1; p<0.001).
doi:10.1371/journal.pone.0073182.g003
Each of the 40 observations included in the analysis was weighted by the sample size to produce the distribution with the estimate of the percent of subjects with a given effect size noted on the Y axis.
doi:10.1371/journal.pone.0073182.g004
In a supplemental analysis, we also evaluated the nine studies that reported the largest [7]–[15] and nine studies that reported the smallest [17], [23], [30], [32], [33], [37], [41]–[43] mean changes in VO2max. These studies are the ones that would be located in the tails of the empirical distribution. Specifically, the mean ± SD increase in VO2max was 0.27±0.05 vs 0.87±0.15 L · min−1 (p<0.001) in this comparison. Weeks of training (6.9±1.4 vs 9.7±1.8; p = 0.004), duration per week (123±67 vs 209±90 min; p = 0.06), and the duration of the intervals for the entire study (479±246 vs 696±264 min; p = 0.12) showed general patterns that suggested the nine studies showing the smallest increases in VO2max were of shorter duration in terms of both weekly training and number of weeks. They also appear to have been less intense (fewer total high intensity minutes) than the nine studies showing the largest increases, although statistical significance was not achieved for all comparisons. Finally, many of the interval training studies reporting large increases in VO2max also used longer (3–5 min) duration intervals.
Discussion
The main finding of this meta-analysis is that interval training produces improvements in VO2max slightly greater than those typically reported with what might be described as adult fitness based continuous training even though many of the studies were of short duration with limited training sessions per week. While the observation that more intense training results in greater increases in cardiorespiratory fitness is not surprising, our analysis suggests that longer intervals combined with high intensity continuous training can generate marked increases in VO2max in almost all relatively young adults.
As noted in the introduction, the Heritage Study demonstrated a mean increase in VO2max of 0.4 L · min−1 in response to 20 weeks of standardized adult fitness style training and marked individual variation was observed [5]. This value is also relatively high in comparison to other large adult fitness style training programs that show increases in VO2max on the order of 0.2–0.3 L • min−1 [47]. By contrast, the studies we evaluated that used interval training alone or in combination with continuous training estimated a mean increase in VO2max of 0.5 L · min−1. Figure 4 demonstrates an estimated distribution of training evoked changes in VO2max for the studies we evaluated. This figure presents a distribution of means whereas the Heritage data is of population values. It is worth noting, however, that the distribution of study effects presented in Figure 4 would appear to be shifted right in comparison to the Heritage data in spite of the fact that some of the studies were of limited duration (6–8 weeks); used intervals that were only one minute long and the time spent during the “work” portion of the interval training session was as low as 10 minutes. Thus, assuming the individual subject data used to generate the summary statistics in this meta-analysis follow roughly a normal distribution, the distribution of individual changes would be comparable, if not slightly better, than the Heritage data even though the overall duration (weeks spent training) were shorter in the studies we evaluated.
The conventional wisdom is that intervals of 3–5 minutes are especially effective in evoking increases in exercise capacity. Consistent with this idea, the nine studies that generated the biggest increases in VO2max (~0.85/min) generally used intervals of 3–5 minutes and high intensity continuous training [7]–[15]. Additionally, many of these studies presented either individual data or ranges for VO2max values pre and post training, and inspection of this data suggests that a marked training response was seen in all subjects. Thus, given the large increases in VO2max seen in these studies, we believe that caution must be used in concluding that at least some humans are incapable (perhaps for genetic reasons) of increasing their VO2max in response to endurance exercise training.
Along these lines, many of the studies showing the largest increases in VO2max appeared to follow a pattern similar to the so-called “Hickson protocol” [7]. This protocol includes 10 weeks of training 6 days/week with interval and continuous training on alternate days. Interval training consists of six 5 minute sessions on a cycle ergometer at a work rate approaching the subjects' VO2max. These work periods are separated by 2 minutes of active rest. As the subjects' power output increases during training, the exercise intensity is increased as needed. On the non-interval days, continuous training consists of running as fast as possible for 30 min/day during the 1st week, 35 min/day during the second week, and 40 min/day or longer thereafter.
The original study of Hickson and colleagues noted that VO2max was continuing to increase at the end of the 10 week training program [7]. However, their subjects declined to continue to train due to the extremely arduous nature of the program. This observation emphasizes that it may be unrealistic to expect significant segments of the population to participate in an exercise training program that permits them to reach their individual upper limit for VO2max. It should also be noted that the high intensity continuous running almost certainly contributed to the large increases in VO2max seen in studies using the Hickson protocol but it is not possible to determine the relative role of each type of training.
Since there is no genetic data on the subjects from the studies included in our analysis it is not possible to use them to retrospectively evaluate the genetic determinants of trainability that have emerged from Heritage [5]. It is well accepted that the increases in VO2max with training are due to increases in cardiac output and peripheral oxygen extraction. However, the contribution of changes in stroke volume, blood volume, capillary density, muscle mitochondrial content and many other factors associated with training induced increases in VO2max might vary on both an individual basis and perhaps via interaction with specific elements of a given training program [48]–[52].
In addition to the well-known limitations associated with retrospective analysis of data reported previously, there are specific limitations to our analysis. First, as detailed above there was wide variability in training programs used in the studies we evaluated. Second, about two thirds of the subjects included in the studies we evaluated were (likely Caucasian) young men and this could explain at least some of the increased responsiveness that we saw. However, sex and age generally do not have major effects on the VO2max responses to training [5], [41]. We also did not include studies in patient populations that have shown marked improvements in exercise capacity with interval training in groups previously thought to have limited trainability [53]. Nor did we include a body of work showing that very short bouts of high intensity exercise followed by longer periods of recovery can have profound effects on exercise capacity [54]. The findings from these studies along with the data reported in our paper indicate that some of the peripheral metabolic adaptations to training require can be elicited by very short periods of high intensity exercise, but that longer intervals are required to see large changes in cardiac output and VO2max. The analysis also suggested some effect of publication bias, particularly with studies with small sample sizes and small effects. While the estimated change in VO2max remained statistically significant with various sensitivity analyses, a clear causal association is inherently limited with this data.
In summary, our analysis indicates that in addition to studies using training programs consistent with various public health guidelines, the basic biology of trainability needs to be evaluated using regimens designed to generate the most robust possible physiological adaptations.
Laatst gewijzigd door Comp78 op 23 dec 2013 09:43, 1 keer totaal gewijzigd.
bambi1969
bambi1969 23 dec 2013 08:56
Geef je ook nog een 'leken' uitleg van de betekenis van de gepresenteerde feiten? Lijkt me voor menig forummer beter begrijpelijk...
Cervélo S3 (2014) - Niner air9 (2013)
bambi1969
bambi1969 23 dec 2013 08:58
En als je dan toch een heel artikel overneemt vermeld dan ook: auteurs, tijdschrift, jaar, issue, bladzijdes. Wel zo netjes!
Comp78
Comp78 23 dec 2013 09:43
bambi1969 schreef:En als je dan toch een heel artikel overneemt vermeld dan ook: auteurs, tijdschrift, jaar, issue, bladzijdes. Wel zo netjes!
yep, update.
Ik zou het niet anders weten uit te leggen dan in de conclusie staat. Dit lijkt me vrij helder en vrij van technische blabla zoals methodenopzet etc.
scepticus
Gebruikersavatar scepticus 23 dec 2013 20:41
Dank voor de link, even de pdf gedownload als leesvoer voor op d'n ipad.
ottorongo
ottorongo 24 dec 2013 23:19
Aangezien ik geen VO2max-meting heb laten uitvoeren zweeft dit begrip ( VO2max) zowat tussen hemel en aarde.
Ik heb alle meerdere artikels gelezen teneinde eens eindelijk inzicht te krijgen in deze materie. Uit sommige artikels meen ik te moeten afleiden dat het VO2max-punt rond de omslagpunt ligt (i.v.m. aerobe drempel) uit een ander artikel meen ik te moeten afleiden dat het max. ligt bij de maximale hartfrequentie (eigenlijk ook begrijpelijk).
Of het nu relevant is of niet gezien mijn ouderdom en medicatie, stel ik mij de vraag of er geen vergelijkende tabellen bestaan die de HF overeenstemmen met de Vo2max. (bv. HF. 85% = gelijk aan 80% VOP2max) dat zou mij een heel eind op weg helpen. Graag accurate cijfers a.u.b.
silvan
silvan 25 dec 2013 15:08
Normaal gesproken is er wel een lineaire relatie tussen je VO2 reserve en je HR reserve. 0 % HR reserve zou dan je rusthartslag zijn; hetzelfde als 0% van je VO2 reserve je zuurstofgebruik in rust is. 100% van beide is bij maximale inspanning, dus je VO2 wordt ook na je 'omslagpunt' nog hoger. Deze range, bijvoorbeeld HRR = [50:200] en VO2R = [1:5] (L/min) heeft een een lineaire relatie met elkaar, zelfs bijna 1:1.
HR is echter wel redelijk variabel. Zelf heb ik wel eens in een korte periode meerdere maximaaltesten afgenomen, waarbij mijn VO2max telkens vergelijkbare waarden haalde. Mijn maximale hartslag was echter bij de ene test wel eens 185, terwijl ik een week eerder of later de 195 wel eens haalde.
ottorongo
ottorongo 25 dec 2013 22:02
silvan.
Hartelijk bedankt, groetjes
Coulthard1984
Gebruikersavatar Coulthard1984 03 jan 2014 23:15
Dat interval training bijdraagt aan het verbeteren van de conditie staat inmiddels buiten kijf.
Dat het ook je VO2 verbetert is een vrijwel logisch gevolg.
Het probleem bij deze (samenbundeling van) studies is dat ze vooral uitgaan van relatief ongetrainde subjecten.
Wat helaas voor ons (forum leden) minder interessant is.
Immers zijn we allemaal meer dan bovengemiddeld getraind.
En daar zit het manco.
Graag zou je willen weten of er ook een significant verbetering is tav het ''verminderde-meeropbrengst principe'': levert het voor (zeer) goed getrainden ook wat op?
Daarnaast hebben wij als wielrenners wel baad bij een hogere VO2, maar zouden we ook nog graag na 3, 4, 5 en het liefst nog na 6 uur nog hard kunnen trappen.
En in dit aspect schiet de interval training (naar mijn mening) toch echt te kort.
Kortom: duur blijft de basis, maar interval is een goede aanvulling.
En de uitdaging zit hem dan in de juiste interval training te vinden; met het juiste protocol en op het juiste moment.
Een juiste duur training (qua intensiteit) is natuurlijk niet zo moeilijk.....
ottorongo
ottorongo 04 jan 2014 00:46
Is dit de "good old coulthard " van vroeger of is dit een nieuwe versie ervan? Zonder de tweede mogelijk te willen beledigen, zou ik toch heel blij zijn met " the return " van " the old-one" (sorry maar ik heb er geen weet van hoe ik hierbij een blijde coockie zou kunnen plaatsen)
scepticus
Gebruikersavatar scepticus 04 jan 2014 09:34
Dit is de oude :-)
Welkom terug :-)
Goed punt trouwens: veel trainingsstudies gebruiken relatief ongetrainde pp en duren meestal maar een paar weken of maanden, en testen maar op een paar makkelijk te meten uitkomstmaten.
Coulthard1984
Gebruikersavatar Coulthard1984 04 jan 2014 18:38
Ja mensen ik ben weer ''terug''. Nooit echt weg geweest, maar ben een tijdje bezig geweest met een ander ''project''. Ik las zo af en toe nog weleens mee...
Komend seizoen (althans het voorjaar) ga ik weer 100% ervoor leven, kijk wat het oplevert. (afgelopen 2 jaar was het een beetje op halve kracht ivm met mijn werk, nu heb ik de komende maanden wat meer tijd)
Mijn leverziekte (PSC) heb ik daarnaast redelijk onder controle, dus ik ben benieuwd.
Daarnaast is er een grote kans dat ik komend jaar (en ander volgend jaar) mijn trainers licentie ga proberen te halen. Dus even weer de materie opnieuw absorberen, discussiëren en de nieuwe kijk op de het wielrennen tot mij nemen. En daar kan ik jullie goed bij gebruiken!
