Shimano Di2 D-Fly / DI2Stats
Hoi,
Voor de DI2 rijders onder ons. Er is een site DI2STATS.com waar je allerlei statistieken kunt bekijken van je ritten.
Shifting statistics - lack of information
There is currently not a lot of information available on gearing and shifting statistics. The most likely reason for this lack of data is the difficulty in keeping track of this information. Accurately tracking and recording gearing selection during a ride has been impractical ... until now!
Introducing Shimano D-Fly
The Shimano Di2 electronic shifting system has been around for a few years. But Shimano introduced a product in February 2014 that allows transmission of your current gear selection wirelessly to a head unit. Recent firmware updates on the Garmin Edge 1000 allow you to record and display this information.
Visualizing your data
Although the gear shifting information is stored in the ride file stored with your Garmin, none of the popular cycling websites (Strava, mapmyride, garmin connect, etc...) are capable of displaying this information as of August 2014. This motivated the need for the website you are looking at now.
Research study
For the first time, it will now be possible to accumulate and study gear shifting statistics on both an individual and group level. By using this website, you agree to participate in the collection of this information. No personally identifiable information will be stored with your data. Any journal articles published from data collected on this website will be meticulously reviewed to make sure that no personally identifiable information is available. A variation of this "agreement" is also included on the import ride page, which means every time you import a ride, you are agreeing to participate in this study.
About the author
I am an assistant professor at Samford University in the computer science department. I am also a Category 1 amateur cyclist and enjoy racing and riding and all kinds of adventures. Learn more about me below or feel free to email me with questions: brtoone@samford.edu
Strava: Strava profile page
Blog: Cycling Adventures with Brian Toone
University website: Brian Toone: ALIVE @ Samford University
Ready to get started
Create an account to get started. You will be asked to identify (optional) what type of cyclist you are to aid in our analysis of the shifting data you upload.
Research study
About the author
- monsieurpinot
interessant dit, overweeg een d fly unit aan te schaffen, grote nut is dat je de batterijstatus kunt bekijken, maar vraag me af wat je er nog meer mee kunt (naast op je fietscomputer zien welk verzet je rijdt). De info wordt dus wel op je garmin opgeslagen tijdens een rit (dus alle schakelmomenten?)
- monsieurpinot
heb inmiddels een d fly unit aangeschaft en di2stats.com eens bekeken, ziet er grappig uit. Je Garmin slaat dus echt elke keer op als je schakelt, en je krijgt dus dit soort grafiekjes:
ook een optie om op een map te kijken waar je welke versnelling reed, die lijkt alleen bij mij niet te werken (een aantal gps punten kloppen wel maar krijg verder een hele rare route in beeld met lange rechte lijnen dwars door de weilanden)
Laatst gewijzigd door monsieurpinot op 23 sep 2015 17:16, 1 keer totaal gewijzigd.
Heb recent aangeschaft een nieuwe Koga Signature met Di2 ultegra
Aangezien de oude vertrouwde shimano flightdeck niet meer door Di2 ondersteund wordt, zal er een nieuw dashboard klokje moeten worden aangeschaft.
Om de tandwiel positie uit te lezen heb ik een draadloze Di2 unit (SM-EWW01) voorzien van het Shimano D-Fly Data Management systeem nodig.
Vraag: bestaat er een kilometer teller waarbij je de grote van de kransjes kan ingeven (net als de ouderwetse flightdeck).
Reden: hierdoor hoef je geen grote combi cadans/snelheid Ant+/BT4.0 opnemer op de fiets te plaatsen.
vraag 2: Zijn er nog meer kilometertellers anders dan ProScio/Mio/Garmin/Wahoo die kunnen communiceren met de Di2 unit.
Laatst gewijzigd door monsieurpinot op 13 jun 2016 22:56, 1 keer totaal gewijzigd.
Reden: samengevoegd met reeds bestaand topic over D-Fly
Garmin trapsensortje is volgens mij makkelijkste. Werkt met elke ANT+ unit
http://www.futurumshop.nl/garmin-cadanssensor.phtml
Hoe wil je zonder ant of bt communiceren dan? Om je verhouding in een kilometer teller te kunnen zien?
Koop een Garmin heb je echt alles wat je je wensen kan qua gegevens.
Snelheid kan via gps alleen voor cadans moet je een klein blokje monteren.
Ik weet niet of je met ultegra shifters de Garmin kan bedienen dura ace wel.
Cannondale Topstone 4.
- monsieurpinot
die meet niet je verzet volgens mij, maar alleen je trapfrequentiedaniel1975 schreef:Garmin trapsensortje is volgens mij makkelijkste. Werkt met elke ANT+ unit
@ts ik heb een 1000, maar volgens mij kan ik alleen de verhouding zien (1/2 of 2/2 voor en 1/11 t/m 11/11 achter). Zal 't vanavond nog eens bekijken. je zou handmatig in je teller je cassette in moeten voeren, want de teller kan natuurlijk niet raden welke cassette je gemonteerd hebt (volgens mij kan dit niet). Wie weet komt er nog zo'n connect APP.
Kan je ingeven je verzet en zien in welke versnelling je op dat moment rijdt ook einde rit geeft die aan hoe vaak voor en achter geschakeld bij samenvatting.
Moet wel een D fly gemonteerd zijn ook kan je zien hoe de accu stand is van de di2.
Ook zonder dfly zijn er ook wel mogelijkheden om je verzet op je 1000 te zien. Er is een app waar je je cassette en voorbladen inklopt en die dan obv cadans en snelheid het "meest waarschijnlijke" verzet toont. Ik denk dat die app alles terugrekent naar ratio's en dan de dichstbijzijnde pakt. Als er tandwiel combi's overlappen of heel dicht bij elkaar zitten dan kan hij er even naast zitten maar meestal herstelt het zich toch en is het heel bruikbaar.
