Syntace C3
lvgh
lvgh 10 apr 2007 02:14
Syntace komt met een nieuw opzetstuur, de C3. Hij weegt zo'n 30 gram meer dan de SLS en 10 gram minder dan de C2. Ik ben geen expert, wat vinden jullie ervan? Subliem ontwerp of marketingquatsch?
Van de website:
C3
Scientific aerodynamics instead of optical illusion
“Space Age ‘Wings’” in turbulent flow areas only cost money and weight, but provide no aerodynamic advantage. The only real advantage comes from the comfort and energy conservation of staying in the aero position from beginning to end. And if we say beginning to end we mean it.
Double Helix Bend
15 years of evolution instead of short-lived solutions like S-Bend or Straith Bend. The hyperextended wrists caused by those „new” positions not only produce fatigue but also cause strain from the arms all the way up into the upper back high enough forcing the rider to arch his back even higher. The result: besides higher caloric intake through strain a worse aerodymamic position. The new Syntace C3 produces, without your help, a „fast”, flat back and a very energy-efficient upper body position.
Higher pedal pressure
In addition: if necessary you can exert even more pedal pressure than with the Syntace C2 und SLS, leading models for 15 years. The support for the heel of the hand, about 20º slanted forward and down directly underneath the wrist and the again biomechanical optimized grips produce exactly the right tension reaching to the upper arm. And offer automatically a power-saving opposite pull for high pedal pressure.
Not enough:
Even the famous, half-lenght position of the Syntace C2 aero bar improved through the new C3 Double Helix Bend. The grip bend, now a little further forward, conforms so well to your hand and your range of motion, you will ask yourself...why not sooner? Even the moderate compromise, S-Bend, is now superflous. Now you can ride faster with the legendary Syntace comfort: much more relaxed than with other aero bars. Owing in part to the much-copied but never reached, pefectly balanced weight support through the Syntace Bio Wings.
Website: Syntace.de C3
Leverbaar vanaf juni, zal wel zo'n 150 euro gaan kosten bij de bekendere online shops.
ironmon
ironmon 11 apr 2007 11:47
Syntace opzetsturen zijn misschien niet de meest blitse op de markt, maar ik heb al heel wat clip-on's 'versleten', en uiteindelijk vind ik mijn oude C2 nog steeds de beste. Weinig aanpassingsmogelijkheden en toch 'past' hij perfect. Ideaal voor wedstrijden over de langere afstand. Verder zijn ze (relatief) licht en oerdegelijk.
De extra kromming die men nu bij de C3 ingebracht heeft is volgens mij ingegeven door het feit dat nogal wat gebruikers van de C2 hun handen in de kromming die de overgang van het horizontale gedeelte naar het opstaande uiteinde vormt, positioneren (iets 'korter pakken') en niet helemaal het opstaande gedeelte omvatten. Ergonomisch lijkt het mij net dat ietsje beter, maar dat moet iedere gebruiker uiteraard voor zichzelf uitmaken. Probleem is dat je meestal geen gelegenheid hebt om opzetsturen uit te testen alvorens je ze koopt ...  Ik denk dat ik mij de C3 ga aanschaffen van zodra hij beschikbaar is.
